Interrupt Driven Character Queue Transfer Mode
[FreeRTOS-Plus-IO Transfer Modes]
Data Direction
The interrupt driven character queue transfer mode can be used with both FreeRTOS_read() and FreeRTOS_write().
Description
ioconfigUSE_TX_CHAR_QUEUE and/or ioconfigUSE_RX_CHAR_QUEUE must be set to 1 in FreeRTOSIOConfig.h for the character queue transfer mode to be available for writes and reads respectively. It must also be explicitly enabled for the peripheral being used within the same configuration file.
When the character queue transfer mode is selected for writes, FreeRTOS_write() does not write directly to the peripheral. Instead the bytes are sent to a transmit queue. The peripheral's interrupt service routine removes the bytes from the queue and sends them to the peripheral.
When the character queue transfer mode is selected for reads, FreeRTOS_read() does not read bytes directly from the peripheral, but from a receive queue that is filled by the FreeRTOS-Plus-IO interrupt service routine as data is received.
The interrupt service routines, and the FreeRTOS queues, are implemented by the FreeRTOS-Plus-IO code, and do not need to be provided by the application writer.
  • Advantages
    • Simple usage model
    • Automatically places the calling task into the Blocked state to wait for the read or write operation to complete - if it cannot complete immediately. This ensures the task calling FreeRTOS_read() or FreeRTOS_write() only uses CPU time when there is actually processing that can be performed.
    • A read and/or write timeout can be set to ensure FreeRTOS_read() and FreeRTOS_write() calls do not block indefinitely.
    • Bytes received by the peripheral are automatically buffered, and not lost, even if a FreeRTOS_read() operation is not in progress when the bytes are received.
    • Calls to FreeRTOS_write() can occur at any time. There is no need to wait for a previous transmission to complete, or for the peripheral to be free.
  • Disadvantages
    • The FreeRTOS-Plus-IO driver requires RAM for the queues. The queue length is configured by the third parameter of the FreeRTOS_ioctl() call used to select the transfer mode.
    • Character queues are inefficient, so their use should be limited to applications that do not require large amounts of data to be read or written. For example, character queues provide a very convenient
      transfer mode for command line interfaces, where characters are only received as quickly as somebody can type.
    • FreeRTOS queues have an in-built mutual exclusion mechanism, but only at the single character level. Therefore, it is guaranteed that the queue data structures will not become corrupt if two tasks attempting to perform a FreeRTOS_write() (or a FreeRTOS_read()) at the same time, but there is no guarantee that the data will not become interleaved if that happens. The application writer can guard against that eventuality using task priorities, or external mutual exclusion (using a mutex for example) if it is necessary.
The ioctlUSE_CHARACTER_QUEUE_TX and ioctlUSE_CHARACTER_QUEUE_RX request codes are used in calls to FreeRTOS_ioctl() to configure a peripheral to use interrupt driven character queue writes and reads respectively. Note these request codes will result in the peripheral's interrupt being enabled, and the peripheral's interrupt priority being set to the lowest possible. The ioctlSET_INTERRUPT_PRIORITY request code can be used to raise the peripheral's priority if necessary.
Example Usage
1/* FreeRTOS-Plus-IO includes. */
2#include "FreeRTOS_IO.h"
3
4void vAFunction( void )
5{
6/* The Peripheral_Descriptor_t type is the FreeRTOS-Plus-IO equivalent of a descriptor. */
7Peripheral_Descriptor_t xOpenedPort;
8BaseType_t xReturned;
9const uint32_t ulMaxBlock100ms = ( 100UL / portTICK_PERIOD_MS );
10
11 /* Open the SPI port identified in the board support package as using the
12 path string "/SPI2/". The second parameter is not currently used and can
13 be set to anything, although, for future compatibility, it is recommended
14 that it is set to NULL. */
15 xOpenedPort = FreeRTOS_open( "/SPI2/", NULL );
16
17 if( xOpenedPort != NULL )
18 {
19 /***************** Configure the port *********************************/
20
21 /* xOpenedPort now contains a valid descriptor that can be used with
22 other FreeRTOS-Plus-IO API functions.
23
24 Peripherals default to using Polled mode for both reads and writes.
25 Change from the default to use interrupt driven character queues for both
26 reading and writing. The third FreeRTOS_ioctl() parameter sets the
27 queue length. In this example, the length is set to 20 in both cases.
28 A successful FreeRTOS_ioctl() call will return pdPASS, for simplicity,
29 this example does not show the return value being checked. */
30 FreeRTOS_ioctl( xOpenedPort, ioctlUSE_CHARACTER_QUEUE_RX, ( void * ) 20 );
31 FreeRTOS_ioctl( xOpenedPort, ioctlUSE_CHARACTER_QUEUE_TX, ( void * ) 20 );
32
33 /* By default, a peripheral configured to use an interrupt driven character
34 queue transfer will have an infinite block time. Lower the block time for
35 reading and writing to ensure FreeRTOS_read() and FreeRTOS_write() calls
36 will return, even in the presence of an error. In this example, both
37 the read and write block times are set to 100ms. Again, for simplicity,
38 this example does not show the return value being checked. */
39 FreeRTOS_ioctl( xOpenedPort, ioctlSET_RX_TIMEOUT, ( void * ) ulMaxBlock100ms );
40 FreeRTOS_ioctl( xOpenedPort, ioctlSET_TX_TIMEOUT, ( void * ) ulMaxBlock100ms );
41
42
43 /***************** Use the port ***************************************/
44
45
46 for( ;; )
47 {
48 /* Write 10 bytes from ucBuffer to the opened port. Note the
49 definition of ucBuffer is assumed to be outside of this function. */
50 xBytesTransferred = FreeRTOS_write( xOpenedPort, ucBuffer, 10 );
51
52 /* At this point, 10 bytes will have been written to the Tx queue,
53 but not necessarily written to the peripheral yet. Check all 10 bytes
54 were written to the queue - they should have been as the queue is
55 20 bytes long. */
56 configASSERT( xBytesTransferred == 10 );
57
58 /* Read 10 bytes from the same port into ucBuffer. Note, this will
59 not read the bytes from the peripheral directly, but from the Rx
60 queue that is populated by the FreeRTOS-Plus-IO peripheral interrupt service
61 routine. The calling task is held in the Blocked state to wait
62 for 10 bytes to become available if they are not available immediately,
63 but the task will not be held in the Blocked state for more than 100ms. */
64 xBytesTransferred = FreeRTOS_read( xOpenedPort, ucBuffer, 10 );
65
66 if( xBytesTransferred == 10 )
67 {
68 /* Ten bytes were read from the peripheral before the 100ms block
69 time expired. */
70 }
71 else
72 {
73 /* The block time must have expired before ten bytes could be
74 read from the peripheral. xBytesTransferred could be any value
75 from 0 to 9. */
76 }
77 }
78 }
79 else
80 {
81 /* The port was not opened successfully. */
82 }
83}
