xQueueSend
[Queue Management]
queue.h
1 BaseType_t xQueueSend(
2 QueueHandle_t xQueue,
3 const void * pvItemToQueue,
4 TickType_t xTicksToWait
5 );
This is a macro that calls
xQueueGenericSend()
. It is included for backward compatibility with versions of FreeRTOS that did not include the
xQueueSendToFront()
and
xQueueSendToBack()
macros. It is equivalent to
xQueueSendToBack()
Post an item on a queue. The item is queued by copy, not by reference. This function must not be called from an interrupt service routine. See
xQueueSendFromISR()
for an alternative which may be used in an ISR.
  • xQueue
    The handle to the queue on which the item is to be posted.
  • pvItemToQueue
    A pointer to the item that is to be placed on the queue. The size of the items the queue will hold was defined when the queue was created, so this many bytes will be copied from
    pvItemToQueue
    into the queue storage area.
  • xTicksToWait
    The maximum amount of time the task should block waiting for space to become available on the queue, should it already be full. The call will return immediately if the queue is full and
    xTicksToWait
    is set to 0. The time is defined in tick periods so the constant
    portTICK_PERIOD_MS
    should be used to convert to real time if this is required.
    If INCLUDE_vTaskSuspend is set to '1' then specifying the block time as
    portMAX_DELAY
    will cause the task to block indefinitely (without a timeout).
  • pdPASS if the item was successfully posted,
  • errQUEUE_FULL otherwise.
1struct AMessage
2 {
3 char ucMessageID;
4 char ucData[ 20 ];
5 } xMessage;
6
7 unsigned long ulVar = 10UL;
8
9 void vATask( void *pvParameters )
10 {
11 QueueHandle_t xQueue1, xQueue2;
12 struct AMessage *pxMessage;
13
14 /* Create a queue capable of containing 10 unsigned long values. */
15 xQueue1 = xQueueCreate( 10, sizeof( unsigned long ) );
16
17 /* Create a queue capable of containing 10 pointers to AMessage structures.
18 These should be passed by pointer as they contain a lot of data. */
19 xQueue2 = xQueueCreate( 10, sizeof( struct AMessage * ) );
20
21 /* ... */
22
23 if( xQueue1 != 0 )
24 {
25 /* Send an unsigned long. Wait for 10 ticks for space to become
26 available if necessary. */
27 if( xQueueSend( xQueue1,
28 ( void * ) &ulVar,
29 ( TickType_t ) 10 ) != pdPASS )
30 {
31 /* Failed to post the message, even after 10 ticks. */
32 }
33 }
34
35 if( xQueue2 != 0 )
36 {
37 /* Send a pointer to a struct AMessage object. Don't block if the
38 queue is already full. */
39 pxMessage = & xMessage;
40 xQueueSend( xQueue2, ( void * ) &pxMessage, ( TickType_t ) 0 );
41 }
42
43 /* ... Rest of task code. */
44 }
